water pump housing ?
Old 05-13-2010, 06:00 AM
crank's Avatar
Originally Posted by SpitfireS,May 13 2010, 01:13 AM
You're talking about bolt #6 and #11 right?
Bolt #6 is an 8mm bolt in my '00 manual, torque is 22 Nm.
Bolt #11 is a 10 mm bolt, torque is 44 Nm.
(you have to do the conversions)
Hope this helps.
yes, and thanks il try and figure out the conversions !
only problem is that the bolts u listed on my car are 14mm for the larger lower 3 and 12mm for the smaller upper 3
and it would be 16ft-lbs for the 12mm uppers and 33ft-lbs for the 14mm lowers...
Old 05-13-2010, 06:12 AM
SpitfireS's Avatar
crank Posted on May 13 2010, 05:33 AM
there are 6 bolts on it, 3 lowers are 14mm and three upper ones are 12mm
With this you mean the wrench size.. right?
In my post I'm talking about bolt size, so the (M)8 bolt has a hex head of 12, etc.. and that's how it is.
Btw.. 22 Nm ~ 16,22 lb/ft, 44 Nm ~ 32,45 lb/ft
http://zxz-rally.110mb.com/art/wartosci/converter.htm
Old 05-13-2010, 06:36 AM
crank's Avatar
ahhh i see, thanks spitfire you really helped me out, and WHY THE FUKK is this not in my HELM manual !!! lol
why is it
16,22 lb/ft 32,45 lb/ft
Old 05-13-2010, 06:46 AM
crank's Avatar
is that 16lbs and 22feet or am i just confused lol
Old 05-13-2010, 06:47 AM
SpitfireS's Avatar
crank Posted on May 13 2010, 03:36 PM
why is it
22 Nm converted to lb/ft gives 16,22 (or 16.22 or 16 and 22/100th), in the manual they round it off to 16 lb/ft.
Old 05-13-2010, 07:01 AM
crank's Avatar
AHHHHHHHH !!! thanks man your awesome !! you an engineer ? i pmd the same question haha
Owen_1987
09-20-2013 10:19 PM
Owen_1987
09-15-2013 10:06 PM
DvS-
02-06-2011 10:00 PM
simons2k
06-11-2006 09:39 AM
Quick Reply: water pump housing ?
