water pump housing ?
for the bolts that connect it to the block ???
i have a helm manual right infront of me, but i cant seem to find it, did a search and seemd to find 33 ft-lb but im not sure.
please help !!
**the housing piece, not the impeller/pump side**
please help !!
Originally Posted by Avionics86,May 12 2010, 08:16 PM
Going by the factory manual (2000-2003): 5 short bolts 16ft and the longer one that goes by the alternator 33ft. The three water pump pulley bolts 10ft.
Good Luck
Good Luck
You're talking about bolt #6 and #11 right?
Bolt #6 is an 8mm bolt in my '00 manual, torque is 22 Nm.
Bolt #11 is a 10 mm bolt, torque is 44 Nm.
(you have to do the conversions)
Hope this helps.
