Water leak inside car
Old 06-18-2007 | 04:08 PM
boosted"S"'s Avatar
Default Water leak inside car
i dont know if this is the right place for this question so if it isnt someone please tell me where to post it. anyway i got a really wet passenger floorboard and i would love to know where to start looking. from what i can see nothing else is wet except for the carpet and i cant see any leaks from the roof dripping down. any help is good help and i sure would appreciate it.
Old 06-18-2007 | 04:16 PM
RedY2KS2k's Avatar
Have you been running the air conditioning lately? On a hot, humid afternoon, drive the car for a while with the air conditioning on. Then park the car for about 15 minutes. There should be a puddle of water on the pavement, approximately under where the passenger's feet would be. If there's no water on the ground, the drain from the A/C evaporator under the dash is probably clogged. Do you hear any splashing sounds from under the dash? Does the A/C sometimes blow "smoke" (water vapor) out of the vents?
This could also be something completely different, but I'd make sure the A/C drains properly before looking at other things.
Old 06-18-2007 | 04:26 PM
RACER's Avatar
Old 06-18-2007 | 05:41 PM
boosted"S"'s Avatar
yeah there is water on the ground after the car is running with the a/c. how do i check to see if the drain line is clogged. i mean where do i start looking.
Old 06-18-2007 | 06:06 PM
mxt_77's Avatar
Search for "clog drain" revealed this:
https://www.s2ki.com/forums/index.php?showt...4&hl=clog+drain
Old 06-18-2007 | 06:39 PM
boosted"S"'s Avatar
WORD! thank you so much ill look at it tomorrow.
Dash
05-20-2014 06:33 PM
scho01
11-07-2008 09:48 AM
ajays2k
06-22-2007 07:21 AM
Xd
08-15-2005 03:17 PM
geminigsr
South Florida
06-03-2004 06:45 AM
Quick Reply: Water leak inside car
