water leak!
water leak!
So I am getting a leak from where the top and the frame seals meet. It runs down from the 2 folds(looks like the first outside fold) on the top of the window frame seal and leaks off onto the black window guide onto the door and then into the door. It has runined my speaker. It only does this on the passengers side. I can see no difference between the 2 sides that would cause one side to do it and not the other. I have looked over all the posts I could find to solve this but no luck. I have tried re greasing all the seals. Still no luck. I have seen some people say to readjust the window but how do you know if its not properly adjusted? Any help would be awesome. Thank you! I have 2 pictures showing where its coming from.
[/img]
[/img]
[/img]
[/img]
Remove the trim, clean out the channel, then glue it back on. You'll see what I mean when you remove it.
