water in the headlight cluster
1 Post
Either the boot/gasket around the bulb is not on properly or the sealant between the lens and housing is bad. Remove the head light, dry it out with a hair dryer, carefully apply a bit of rtv around the edge of the lens (on top of the original seal), reinstall the light, clean the boot, lube it with rubber friendly stuff (your choice), reinstall the boot.
