Water Drips on the Passenfer's Carpet
Need some help, I just notivced today that I have water dripping in the passenger's carpet. It's not coming from the soft top, does anyone know how to fix the problem or should I take it to a shop?
if the water is dripping under dash on passenger side carpet that is a easy one. your drain for the evaporator box is clogged. if you just had your oil changed alot of oil tech's will put a bolt in drain to prvent water from dripping on them. if this is the problem just pull the bol out. it is also possible that the hose came diconected. if so just push nit back on. you could also take it to dealer to have the box cleaned. they use a foaming agent that kills all mold and mildew and usualy will unclog the drain tube. i think they charge like 69.95. good luck. easy one to fix.
sorry i forgot to say that the drain hose will exit under car on passenger side under where passengers feet go.
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
locate the drain tube, usually black rubber hose under the passenger side of car. Shoot some air in there and you will get a rush of water coming down. The evap box was so cold that it became a block of ice. Very common issue on many cars.
Gernby
05-24-2004 10:40 AM
NYS2K
08-01-2003 05:12 AM
