Water dripping from black box
If you don't have a hose obstruction (check that first) you probably have the common condensation leak in early AP1's... there was even a TSB to fix it. The seal on the box is not adequate.
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
crawl undneath the passanger side and look for a little hose the sticks out the bottom of your car... this is the drain hose that the A/C unit expels the condesation out of... it will most definately be kinked or plugged, unstop the clog and move out of the way because close to a gallon of water is about to drain out that little hose!
It happened to me so I am sure this is the problem!
