Of the wall swap and I need some info please
Hi, so I don't own an S2000 but I am hoping that some guys will be able to assist me with some questions so I can get started on the fabrication part of swap. I am looking to swap a F20C into a 93 RX7. My questions are as follows:
What is the length of the S2000 drive shaft?
What is the length of the S2000 transmission?
Which way does the drive shaft rotate when sitting in the driver seat? I was told counter clockwise (wasn't 100% sure) but just want someone to verify this for me please.
That's all I have for now but I will post all questions here as they come about. The only reason I am asking is because I don't have my donor motor/transmission yet and would like to start getting a game plan and measurements so the brainstorming can begnin (until I can get the motor/trans).
I hope you guys will assist me with my questions! Thanks in advance.
Drive shaft spins clockwise, just like the engine when looking at the car from the front, so counter clockwise when looking at it from the rear(ie driver's seat). I know because when doing a valve adjustment, you turn the crank clockwise to go through the firing order. I can give you approximate measurements of the transmission and driveshaft probably tomorrow, as I'll be too tired when I get off work tonight. Drive shaft is about 3 and 3/4' - 4' long, transmission is about the same.
