VTEC Window and engagement conditions
Hello! Does anybody know under which conditions (RPM and MAP) does the vtec engage in the AP1? I need this information for lowering the vtec engagement point.
Thanks!
Thanks!
Received 1,418 Likes
MAP doesn't affect VTEC. And engagement RPM is about 6k. Not sure why you'd need to know that if you're changing it anyway....
I am using a piggyback ecu so I need to know when the ECU thinks its not in vtec to add ignition timing. I am pretty sure that MAP or TPS affect vtec engagement.
VTEC only engages over some TPS point, but I don't know what point that is. But it's definitely not engaged when you are off the throttle, and definitely engaged at full throttle.
Might have more luck posting this in engine management.
Not sure for AP1 but AP2 06+ stock tune according to flashpro is:
VTEC RPM Window: 5900-6400
RPM 6000 6100 6200 6500 6700
MAP 0.869 0.869 0.735 0.541 0.541
I am using the Emanage ultimate
Thanks! Any idea what's happening after 6700 rpm?
