VTEC turns on at 6200 RPM?
Okay I am tired of searching and reading, can't find a thread that covers this issue...
I noticed in the last couple weeks that VTEC is delayed and kicks at 6200 RPM??? The transition is crisp but late. Anyone have any ideas why?
- Car has 89k miles, have always run Mobile 1 since purchased at 24k miles.
- Check the screen filter at the VTEC valve and it is perfectly clean.
- Measure solenoid resistance at 15 ohms (did not suspect but did while apart)
- Last oil change was about 2500 miles ago.
- Verified oil level, I keep it between half and full on the stick.
- Changed oil filter just for fun.
- Reset the ECU.
- Did the MAP whack as some suggest
- No CEL has come up while having this issue
- Car runs great otherwise
- Reset the ECU.
Hmmmm, on the same note it seems to me that my VTEC engages at an even higher 6500rpm, which I thought was normal, because it sounds like the correct time to switch over and it pulls very hard from then on. This is OK right? I do live at 4000feet above sea level if that has anything to do with it.
Originally Posted by Billman250,Aug 5 2007, 08:45 AM
Are you going by some other means to check the RPM or are you looking at the factory tach?
By factory tach, every s2k I've driven (ALOT) is 6k.
I apologize for omitting where it normally turned on for my car which is about 5800 best i could tell using the dash tach. So it appears to be a delay on the order of 500 RPM.
At least it's within what is considered "normal.'
