Vtec "surging"
Old 02-04-2007, 03:57 PM
JaxShawn's Avatar
what's the fix?
Old 02-04-2007, 03:59 PM
Banned
REVZ TO9's Avatar
I had VTEC problems and it was because my clutch was slipping at the higher rpms
Old 02-04-2007, 04:03 PM
gomarlins3's Avatar
Originally Posted by JaxShawn,Feb 4 2007, 05:57 PM
what's the fix?
If Billman say's it the MAP whack, it's the MAP whack.
https://www.s2ki.com/forums/index.php?showtopic=209708
Old 02-04-2007, 04:55 PM
JaxShawn's Avatar
thanks, my next day off is now designated at the s2000 day
Old 02-04-2007, 07:49 PM
TitusS2k's Avatar
Its prolly from your high/low crossover your feeling. My LsVtec used to do that all the time, Vtec would come on spike, then drop- then begin to pull like a bat out of hell.... Get a Tune and youll be okay!
Old 02-04-2007, 08:37 PM
JaxShawn's Avatar
V-fac2 is on my list of mods that are coming in the next few months
Old 02-04-2007, 08:50 PM
SenderGreen's Avatar
Originally Posted by JaxShawn,Feb 4 2007, 04:57 PM
what's the fix?
Here is the fix according to Honda, skip the whack.
https://www.s2ki.com/stor/library/TSB/a04-073/index.htm
EDIT: I guess I can see the MAP whack as a possible diagnostic step. However seeing as how no one can explain it or why it "MAY" work temporarily, I don't put much stock in it. If you haven't already performed the TSB linked here, I would. If you go to a dealer and explain the problem and ask about the TSB they may even just do it for you, stranger things have happened. They are not obligated as this is not a recall only a TSB. At any rate the parts required come as a set including the MAP itself and a special zip-tie. You can order just the zip-tie itself for like $6 or $7. I ordered just the zip-tie because I was not having the problem, just wanted to prevent it. Since you are already having the problem you may want to go ahead and replace the MAP along with adding the zip-tie like Honda say's to. I don't think the replacement MAP sensor is even an updated part, however I don't remember this for certain. I think Honda just wants you to replace a MAP sensor that is already showing these symptoms with a new one. Good Luck.
Old 02-04-2007, 08:56 PM
Tyraid2K's Avatar
ya vtec wouldn't turn off then on again at higher rpms unless something was seriously messed with, a nice VAFC tune should fix your issues
Old 02-04-2007, 09:14 PM
Banned
REVZ TO9's Avatar
what are the major differences between the VAFC1 and VAFC2?
Old 02-05-2007, 02:32 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
VAFC will fix squat.
LIGHTLY tap the map sensor about 30 times with a screwdriver handle, while reving the engine up and down just above idle, like 1000-1400. This will at least rule the map is at fault.
My car as well as a few customers have had the exact issue you described. A new map (or even the map whack) will fix it.
Quick Reply: Vtec "surging"
