VTEC Solenoid top half gasket
Old 03-10-2015, 11:47 AM
  #111
HighwayStar's Avatar
Yup mine is leaking too. I have a question i looked at mine its hard but not cracked If i give it a massage with an Happy ending with shin etsu grease would that work? Also there no risk of the grease killing the motor right?
Old 03-10-2015, 01:19 PM
  #112
klemen123's Avatar
has anyone tried this one ?? http://www.ebay.co.uk/itm/OEM-Honda-...item1e9b176b51
Old 03-10-2015, 02:52 PM
  #113
Billman250's Avatar
Received 1,398 Likes on 837 Posts
I have tried that one, impossible.
Old 05-05-2015, 05:23 AM
  #114
keyboarddriver's Avatar
Any updates on this? I'm starting to see oil in this area as well.
It sounds like this gasket is going to become an increasingly common problem, with no cheap solution.
Old 05-05-2015, 05:34 AM
  #115
Billman250's Avatar
Yes this is finally under way, this should be a superior lifetime product, will update soon
Old 05-05-2015, 06:08 AM
  #116
windhund116's Avatar
Received 1,533 Likes on 1,037 Posts
Originally Posted by Car Analogy
Sounds like someone used to the craziness of German cars, where its common to have to buy a whole, expensive part just to get the small, poorly designed piece of it that normally fails, and for some reason being a German Car everyone just accepts it and pays through the nose for the part.
My old 2002 used natural rubber for seals and belts. Darn things would harden with use, esp in smoggy conditions. So hard, that the seals would wear out the metal parts. Perfect looking seals --- worn out shafts or valve stems.
Old 05-05-2015, 06:35 AM
  #117
V6 Donut's Avatar
SWEET!
Old 05-05-2015, 09:15 AM
  #118
bouford's Avatar
Old 05-23-2015, 06:34 PM
  #119
Geebs's Avatar
Bump!
Count me in, mine started leaking today!
Old 05-24-2015, 05:08 AM
  #120
Billman250's Avatar
Still under way will update as the info comes in...
Quick Reply: VTEC Solenoid top half gasket
