VTEC Not Kicking in Hard
Old 12-31-2008, 01:17 PM
bioman's Avatar
Thumbs up VTEC Not Kicking in Hard
Well, I am about to pick up a '05 S2k. The last one I drove, an '04, the VTEC would kick in really hard. It would seem like a totally different car when it hit.
In this car, when the VTEC kicks in, it's not that noticeable. Seems like the car is very linear and it doesn't have the jolt like the other S2k's I've driven.
I'm thinking of switching out the spark plugs and adding some fuel injector cleaner/additive. Maybe even Seafoam.
Anyone have any suggestions on what kind of fuel cleaner I should get?
Any other things I should replace/change or look at to combat this issue?
What spark plugs do you recommend?
I've had the car inspected and engine is all good and so is everything else. Maybe a bad batch of gas as well?
Thanks in advance.
Old 12-31-2008, 01:22 PM
Skatethesea's Avatar
does it have any work done? Like a header? That can make the transition into VTEC smoother. But if you think that it just isnt making the same power then have your VTEC solenoid checked out.
Old 12-31-2008, 01:26 PM
bioman's Avatar
No, it doesn't really have anything other than a grounding kit.
I'm going to change the oil very soon. Along with spark plugs and I will add some Techron fuel additive. If nothing happens, then I will take it to the dealer for the solenoid.
Are OEM Honda Sparkplugs the best?
Old 12-31-2008, 03:55 PM
$Piker's Avatar
Stick with the NGK oem spec plugs if it is not modded. It could be fuel related too.
Good luck.
Old 12-31-2008, 03:57 PM
RedDawnFX's Avatar
Hmm I have only v-teced in second gear. I don't really feel a boost, but maybe that's because I am not switching from second into third. (Just tried to test it without going insanely over the speed limit)
I have a 2004 and the transition seemed smooth and unnoticeable besides the engine making the noise of it spinning faster.
Edit: Actually now that I think about it, it might because my oil is low (Below the dipstick x's) but the check oil light is not on. I just checked my oil tonight and need to fill it up tonight before I go out driving again. (I bought it from the dealer 2 weeks ago)
Old 12-31-2008, 04:19 PM
Banned
2007 Zx-10's Avatar
how many miles? if the car was driven easy (low rpm) it can make the transition sluggish...mine was that way until I drove it hard and changed the oil to a good synthetic
Old 12-31-2008, 04:37 PM
bioman's Avatar
It was at WOT. About 36k miles. I will update this thread after I do said items on post above.
Old 12-31-2008, 04:52 PM
RedDawnFX's Avatar
Just filled up my oil, going to try it one more time. Mine is also about 36k.
Old 12-31-2008, 04:53 PM
bioman's Avatar
Let us know what happens.
Old 12-31-2008, 05:15 PM
Slows2k's Avatar
I never thought the AP2's had a abrupt VTEC switchover
Quick Reply: VTEC Not Kicking in Hard
