VTEC not engaging, speedo wildly inaccurate
Old 09-22-2015, 02:29 AM
NNY S2k's Avatar
Originally Posted by windhund116
Other way around. 70MPH = 112KPH. His 70MPH (GPS) shows 40.
Maybe GPS was set on KPH
Levi
Old 09-22-2015, 02:27 PM
windhund116's Avatar
Received 1,540 Likes on 1,044 Posts
No, I think if GPS was set on KPH... true speed would be shown (112 KPH). Nothing around "40."
Old 09-23-2015, 05:39 AM
NNY S2k's Avatar
^^^^If GPS was showing 70 KPH then speedo showing about 43 MPH would be correct.
Levi
Old 09-23-2015, 05:53 AM
OK... got it.
Old 09-24-2015, 09:37 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Please let us know about the ground bolt and what you find.
if that bolt is loose or ground not in place, the speedo will sit between 35-45mph, and just kind of hover there even if you're doing 80.
Old 09-24-2015, 11:42 AM
Grulks's Avatar
Haven't had a chance to get back there yet.
The speedo is def on MPH, NOT KM. Its so weird, VTEC/Speedo had no issues for 10 days or so when the engine was swapped. Then all of a sudden VTEC intermittently stopped working. First thing I checked was oil, and that was not only topped up, but very very clean (after roughly 600 miles).
The speedo sometimes is correct (based on GPS readings) and sometimes way low (20-30 mph low, while in 5th/6th gear).
I'll check and see if I can feel around there when I get off work tonight.
As always Billman, thank you so much for you knowledge and expertise. There's nothing worse than dropping $4000 to have a new engine/trans swapped in, and then all of a sudden your shit STILL not working 100%
Old 09-24-2015, 12:46 PM
Billman250's Avatar
20-30mph low.
Ground wire back of head near 100%.
frankdatank91
10-07-2012 09:12 PM
nicholasbartleet
03-03-2009 04:11 AM
qbmurderer13
05-20-2008 07:56 PM
hahnn002
06-15-2006 12:39 PM
baxdatass
10-07-2002 08:05 PM
Quick Reply: VTEC not engaging, speedo wildly inaccurate
