VTEC HAS GOOD DAYS AND BAD DAYS?
Old 07-06-2005, 05:21 PM
landfighter's Avatar
xviper, do we really have a vtec filter screen? or was that to be taken like "greasing the muffler bearings". if we do, where is it?
Old 07-06-2005, 05:30 PM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Yes, we have a VTEC screen.
It goes in between the VTEC valve and the cyl head.
Old 07-06-2005, 05:44 PM
cool..beans,billman. how often should it be cleaned? do i need a new gasket or anything if i where to remove the vtec valve? i have no problem now, but if i do later just want to be prepared.
Old 07-06-2005, 05:49 PM
xviper's Avatar
It is part #14 in the following diagram:
http://www.slhondaparts.com/browse.asp?Mod...&ViewParts=true
Old 07-06-2005, 05:53 PM
cool, thanks xviper
Old 07-06-2005, 06:26 PM
xviper's Avatar
In answer to your cleaning question, there is no set time interval to clean this thing. It's a matter of "when all else fails", take a look at it. If you use a good brand name oil and change it as per the recommendations in the owner's manual, this screen should not need your attention for the life of the car. However, if you neglect your oil changes or don't change the filter with a good one and at each oil change, this screen "could" get clogged. As you can see, it doesn't cost much, so if you are going to take it apart to look at it, you may as well throw a new one in.
Old 07-06-2005, 07:05 PM
gotcha, thanks for the info. like i say, as of yet i have had no issues. i run mobil 1 syn oil, changed w/honda filter every 3k miles(probably not necessary, but better safe than sorry)so, i hope i don't have to but now i know just in case.
Old 07-06-2005, 07:16 PM
Slows2k's Avatar
If this screen gets clogged, you will eventually get a P1259 VTEC failure code stored. When this code is present, VTEC will not engage and you wil have a much lower rev limit. It's the PCM's way of dsaving the engine from being run in VTEC without enough oil pressure and volume.
Old 07-21-2005, 10:31 PM
silver_AP1's Avatar
it's most likely ur 'MAP' sensor.. i had the same prob, took my car into honda and found out there's a bulliten about that... should be under ur warrenty
sleepingb18
07-30-2007 07:40 PM
will gill
11-26-2004 08:17 AM
HisforHonda
08-08-2002 01:53 AM
S2KRoadster.com
06-14-2002 02:59 PM
Stealthy_S2K
07-14-2001 11:49 AM
Quick Reply: VTEC HAS GOOD DAYS AND BAD DAYS?
