vtec
#21
Originally Posted by jimknapp,Nov 14 2007, 07:19 PM
For a quick check of your VTEC, first unplug it. Then clip a jumper wire to the wire from the VTEC and then with the engine running at least 3000 RPMs touch the other end of the wire to the Positive (+) post of the battery. The engine should clearly sound like an over cammed hot rod (which in fact it is at that point), rough "cammy" idle and all that. If you add 12V to the VTEC solenoid at too low RPMs, there will not be enough oil pressure and your motor will simply make some awful, but basically harmless, noises.
I used to just put a micro switch under the throttle pedal that supplied 12v to the VTEC whenever I went to full throttle. Sort of like NOS, if you will. Just remember to not go WFO below about 3800RPM or it really shakes things up.
Keep the shiny side up.
Jim
Jim
are you positive there are is no harm to the engine? because if it was this easy why would people buy stuff to lower vtec point...
there should be a DIY on this!
#22
Received 1,402 Likes
Originally Posted by hondafrvr,Nov 17 2007, 04:00 PM
damn thats crazy!
If you lower the VTEC, you need to have the car tuned. If you supply the solenoid with power, regardless of oil pressure, VTEC will operate.
The ECU is what usually controls VTEC. It looks @ oil pressure, tps, rpm, cts, etc. to operate VTEC. With the switch idea, you're just bypassing it all. The engine does not create enough Oil pressure to engage VTEC very low. There is a danger there. Engine speed should be atleast 3k RPM for safety reasons alone.
Know how the S2000 "lacks torque"? If you open the ginormous VTEC lobe at low RPMs....you're going to have LESS torque than you allready have.
The fuel tables dont call for a big cam down low. The S2000 is sensitive to say the least.
You will lose power. Your car will be slower.
#23
#24
Okay, Serious, I'll admit that I don't know anything about stock mapping. I only use an after market ECU and we custom map only for idle and WOT, no cruise, no emissions, nothing else. So my comments are only for that environmet.
I have experimented on the dyno with turning on VTEC as low as 2000 RPM. Also I have used a toggle switch to turn it on at say 5000 RPM in first gear, made a pass with it on the whole time and then forgotten to turn it off after a run as the engine returns to idle. Hence the change to a micro switch under the throttle pedal.
Leaving the VTEC switch on at idle didn't and doesn't seem to hurt anything. There's just a lot of racket from the valve train as the little pistons inside the rockers try to make up their "minds", and it does sound really weird.
If you run the engine up from say 2500 RPM with the VTEC on it is just a hopeless mess until about 3800 - 3900 RPM at which point it settles down and begins to make some power. By 4000 it is pulling clean. So I come off the line easy (not a lot of traction on the salt anyway) and lean into the throttle and if I'm lucky push to WOT at about 3800 anyway since the engine just goes right on up past 4000 almost immediately.
And again I caution we are doing custom mapping, but I've found VTEC to make more power than no VTEC from 4000 to 9500. Above that, I believe all the extra weight in the valve train begins to cost you power, but you need different cams at that point anyway as you venture on up into the 10,000 - 11,000 zone.
Keep thge shiny side up,
Jim
Jim
#25
Originally Posted by S2-3456789-K,Nov 17 2007, 06:01 PM
am i reading this wrong or are the above statements contradictory? sorry if i'm misunderstanding soemthing
Then I went on to say it's not a good idea at very low RPMs.
#26
the vtec solenoid only opens a gate that allows oil to pass through and activate the vtec mechanism. like you said, it still requires sufficient oil pressure, so the gate will open, but due to lack of oil pressure, the vtec mechanism will not engage. is that what you're saying?
