VSS (vehicle speed sensor) ?
The speed is measured via the VSS (Vehicle Speed Sensor) which is located on the transmission. It reads pulses from a shaft rotating inside the transmission then sends them to ECU (Blue/White wire)where they are converted to an indication of speed.
Question: Is the Blue/White wire # 9 pin at the ECU is "output or input" ????
Thanks
Thanks
kartectuning
04-16-2017 09:17 AM
