VSA/Triangle Light - Steering Wheel Angle Sensor
Hi all,
Had an EP3 wheel on my car and swapped back to my OEM steering wheel and suddenly I have this VSA and Triangle light on. All I did was pull off the wheel and put the new one on, battery disconnected while I did it. Had my friend run the codes with his Honda tool and came back with a number of faults including the failure of the steering wheel angle sensor. Not sure how I could have broken it, but does this sound correct? Wanted to get another opinion before I spend $200 on a new sensor.
Chances are when you replaced the steering wheel, you moved the steering wheel angle sensor (which is behind the ABS clock spring). If the steering wheel angle sensor is off by a small amount (~5 degrees), it will throw the code you described. You can read and reset the angle sensor using a Honda HDS. I would try that before you replace the sensor. Unless you were rough with the steering wheel swap, that sensor should be fine.
Survey S2000
02-05-2009 12:04 PM
