VSA question
Old 04-09-2007, 09:22 PM
R3DS2K's Avatar
Originally Posted by vishnus11,Apr 9 2007, 02:24 PM
You must be one of those special humans with 6 legs, where you can control the braking and throttle at each wheel individually
Sorry to say it, but VSA WILL outperform the human brain when it comes to driving in certain conditions. Of course there is no subsitute for astute judgment.
vsa more consistent compare to a human
Old 04-10-2007, 04:13 AM
Slows2k's Avatar
Originally Posted by vishnus11,Apr 9 2007, 04:57 AM
How so?
I wasn't aware that the car even had to be turned on when using an on car lathe. I have yet to resurface the rotors on my S since its an 06, but if I remember correctly, when doing the rotors on my previous cars, we'd just put it up on the lift with the tranny in neutral, attach the lathe, and let it do its thing. Any reason as to why the car should be turned on in the first place?
On a FWD Honda you resurface the front rotors in gear, using the engine to drive the rotors. On a S2k you use a separate power drive for the front rotors, and 2nd gear to cut the rear.
The lathe uses a separate power drive that not normally used for non-drive wheels.
Resurfacing on car ensures the rotor face is resurfaced parallel with the hub.
Old 04-10-2007, 06:41 AM
vishnus11's Avatar
Ahh, in my case, we use a powerdrive for both axles - i.e. in the case of the S2000, I would hook the drive upto the hub, leave the tranny in neutral, and machine the rotors. Any reason why you would NEED to use the car to power the drive wheels when using an on car lathe?
Old 04-10-2007, 07:25 PM
R3DS2K's Avatar
um i have a 94 honda accord and i had the front rotors cut without the car being on.. no need to use the cars powertrain to turn the rotors if the on car lathe is self powered.. unless the lathe you have is suppose to be done that way but i never seen it cuz most on car lathes i seen cut it with its own power
Old 04-10-2007, 11:42 PM
SpitfireS's Avatar
vishnus11 Posted on Apr 10 2007, 03:41 PM
Reason = Torsen LSD.
Rotating just one rear wheel for a certain time (a minute?) may damage your Torsen LSD.
While driving the Torsen works on the rev difference between left & right wheel.
With an on car lath you're introducing a LOT of rev difference for a time that will never occur driving.
About the same as driving with 2 different rear tires (different size, different wear, ect).
Thats also why one has to put the front wheel on the rear and the spare on the front in case of a flat rear. (check your manual for that )
Old 04-13-2007, 05:33 PM
R3DS2K's Avatar
ahh berry good info.. didnt know that
Old 04-14-2007, 01:14 PM
jyeung528's Avatar
Originally Posted by vishnus11,Apr 8 2007, 02:40 PM
You must manually disable VSA everytime you start the car if you wish to operate the vehicle without the stability control present (please don't do this on public roads)
why not??? what about the s2k's that don't have VSA?
i've been driving without VSA for several years...should i stop driving on public roads?
Old 04-14-2007, 02:56 PM
Slows2k's Avatar
Resurfacing on car ensures the rotor is parallel with the hub.
Old 04-14-2007, 02:57 PM
Slows2k's Avatar
Not all on car lathes are self powered. The Kwik Way lathe uses a separate power drive.
Old 04-14-2007, 04:35 PM
R3DS2K's Avatar
yes get of the streets and on a track lol
Quick Reply: VSA question
