VSA LIGHT?
VSA LIGHT?
HELLO GUYS..
WELL I JUST BOUGHT AN MY05 A MONTH AGO AND THE VSA? LIGHT HAS ALWAYS BEEN ON..CAN ANY OF YOU TELL ME WHAT IS THE VSA FOR? AND HOW CAN I TURN THIS OFF? ANY HELP WOULD BE MUCH APPRECIATED...THANKS TO ALL.
why are you typing in all caps?
my vsa light came on and off intermittenly and it was because my front brakepads were getting low. but it can something else in your case.
VSA is "Vehicel Stability Assist" (traction control). and i dont think you have an 05..i believe 06 is when the VSA came on the car.
yes I do have an 05, thats what the tittle says, I doubt the title will be wrong..
My brake light,check engine and vsa lights are on, dont know why..anyone can help?
thanks
thanks
thanks
thanks
Originally Posted by 05s2kmia,Aug 2 2009, 12:21 PM
Well it has the vsa light on, and if the title says its from 2005 it should be from 2005,I don't really care the year,all I want is to fix it.thanks
The royal navy blue was also never released in N. America, so it's either a custom color, or you're wrong again. If you're referring to Laguna Blue Pearl, that color came out in 2006. And if you do have a Laguna Blue, your car might have been purchased in 2005, but it was a 2006 model. Thus, leading us to the beginning by reviewing f23's suggestion.
Here's a color comparison for you:
Royal Navy Blue:
https://www.s2ki.com/forums/index.ph...owtopic=181728
Laguna Blue:
https://www.s2ki.com/forums/index.php?showtopic=339169
youve had the car for 1 month. and you are arguing with people who are knowledgable and have owned multiple s2000 (myself 2) and trying to help.
e-brake light on means your e-brake is up or since your brake pads are so low, your car thinks that you are low on brake fluid. pop the hood and check your fluid. if your fluid is low check your brake pads. getting new pads will increase the fluid level in the brake fluid reservoir.
VSA works in direct conjunction with you brake system and the ECU..so if your brake light is on, then the system thinks theres a fault; hence throwing the VSA light and check engine light on.
-a
-a
^ LOL this guy a tool
i have a car thats an 06 but it says purchased in 05, maybe your reading comprehension is off?
Anyways your best bet is to take it to the dealer, theyre really friendly and they always have the best prices, might even be free for you
