VSA and Brake light on
Red brake light means there's something wrong with your base brake system (or your parking brake is on, but I'm guessing since both lights are on it's not the parking brake switch). To quickly test if its the parking brake switch or a problem with the braking system, try to fold the top down/up with the parking brake OFF. If it allows the roof to open or close, then it's the parking brake switch. I don't recommend driving with the red brake warning lamp on. VSA is disabled since the problem with the brakes is detected.
I would start by checking your brake fluid level.
