Vortech SC update
#21
Hi
Pleased to say I have had excellent service from Vortech. Spoke to the design techs who gave me a lot of tests. It turns out that there was a problem with the ECM holding vacuum (only held a partial vacuum) which was not enough to bleed boost but was creating less fuel pressure and so causing a lean condition. The timing box pulls about 4 degrees and as I run 98 octane or higher it has little effect. Looking at the design fueling maps and the ones posted I think a next step has to be a programmeable piggy back ECU. If there are recomendations in this area for FI then I'd appreciate the feedback. My criteria are:
Simple to tune on rolling road: 2-3 days dyno time and tunable by good tuning house
Controls injectors and not just fool map sensor
Controls timing relative to load/ RPM
Allows engine safety features such as VTEC delay (I do not want to change VTEC point)
Allows ECU to run all other functions
Car is used mostly on road
I see that a pre-configured AEM is mentioned in the linked thread. I am also outside the USA and AEM is not supported in any of my dealers. I would need to look at a Japanese system.
Many thanks
Many thanks
#22
Originally posted by Maca
Hi
Many thanks
Hi
Many thanks
2. I think the closest you will come to your requirements is the Greddy e-Manage unit: http://www.greddy.com/products/electronics_frame.htm
-YS
#23
Hi
I can't get the VAFC to work with my application. I have positioned it downstream of the MAP box (between MAP box and ECU). When the tuning people try to chnage this they say it has no effect. Anyone got base measures for a Vortech out there?
MACA
ps Checking out the air:fuel again on another dyno session on Monday!
MACA
#24
Hi
MACA
Hi
MACA
-YS
#25
Why wouldnt the AEM EMS take care of all of these problems? I planned on going with that usit and bypassing the Vortech module all together and would like to know before plunking down the big bucks for the unit...
#27
I have the Vortech SC
But seriousley good look with the set up it's one that I will be following very closely and if your ever near my neck of the woods I'd love to have a nosey at your motor "for inspiration and that".
On that note Chris @ Hyper sports & racing is having an official opening day of his new workshop on Jan 11th "I think" and I know you've purchased stuff from him before so if your around it would be nice to meet you & some magazines should be there to do a review.
Andy
(looks like the turbo route for me )
#28
Andy,
I used 'Hyper Sports' as a quick fix. I tend to use Tuning Japanese in Aldershot as they have a good rolling road and can fit me in at short notice as I'm a regular. Tim also goes to Japan four times a year and researches stuff whilst he's there. He's going to be looking into suspension mods and Greddy bits for me whilst he's there in January. Probably see you at a Supermeet!
MACA (suffering still from fuel tuning problems)
#29
Maca did you look at the Turbo option or just the SC route?, just wondered what made you go with the Vortech??
It gives me some more confidence that someone has got an F.I. S2000 in the UK, I really don't know what road to go down SC or Turbo do you have any helpfull advice you could give me to sway my decision either way?, I've found that no-one over here will even entertain me unless I have at least
