ok i have never used nitrous....so i don't know how dangerous it is...
so my question is could and Vortech SC/w ac S2000 hold a dry 50-65 shot with stock internals....
lets say squeezed twicea week...prob won't even be that much..
No not DRY kit! You wont be able to get enough fuel out of the stock injectors unless you have upgraded your injectors and running AEM EMS. You'll be running extra lean and then....BOOM!
Stock injectors are maxed with the Vortech alone. Also, you have to be very careful even with wet kit becuase the Vortech uses an FMU that increases fuel pressure with increase in boost. This will disrupt the tuned AFR of the wet kit.
Bottom line --- No Dry kits with Vortech unless you have larger injectors and precise control.
