Vortech owners - Watch out!
Old 08-01-2004, 03:38 PM
xviper's Avatar
Default Vortech owners - Watch out!
On my last road trip, I checked my engine bay for anything odd. I usually do this as part of my oil check routine on a long trip. I noticed that the BOV filter was actually putting an indent into the AC metal line. Thank goodness I found it before it wore a hole right through it. I removed the filter till I got home.
Here are some pics to show what it looks like and what I did:
First one is of the worn away part of the metal line through the foam insulation:
Next two show what I did to resolve the issue. Vortech shows to install the BOV with the filter pointing down. I removed the BOV and turned it upside down and re-installed the filter:
I have filled in the indent and worn away foam insulation with a big glob of clear silicone seal. Black would have been nice but I didn't have any.
I highly recommend you go check this aspect of your installation and attend to it as necessary. I also recommend that all those who are about to install a new Vortech put the BOV as shown in my last two pictures.
Old 08-01-2004, 03:55 PM
Slows2k's Avatar
I have about 10mm clearance on mine. My aftercooler is pretty upright with the AN fittings though.
Old 08-01-2004, 04:48 PM
xviper's Avatar
It's odd that they don't all sit the same. My cooler is angled down to toward the blower, thus making the filter touch the AC line.
Old 08-01-2004, 06:07 PM
Slows2k's Avatar
The silicone connection sleeves allow a very little amount of play. My aftercooler is pushed as far back towards the throttle body so the different fittings I used don't hit the radiator.
Old 08-01-2004, 06:08 PM
Slows2k's Avatar
Old 08-01-2004, 07:05 PM
xviper's Avatar
The angle on mine doesn't look much different than yours and my filter was pushed as far as possible onto the BOV mounting base.
Old 08-02-2004, 02:25 AM
MechaGodzilla's Avatar
Interestingly, I discovered this exactly one year ago and was similarly alarmed.
https://www.s2ki.com/forums/index.php?showt...0&#entry2053839
MG
Old 08-02-2004, 04:49 AM
Mirror's Avatar
yeah that's where I learned about a year ago. I found that if you turn the filter 90 degrees it does the trick.
Old 08-02-2004, 05:27 AM
bigpurp's Avatar
Thx for the heads up, x-man and mecha.
I will go out and check mine tonite...
Old 08-02-2004, 05:28 AM
xviper's Avatar
How'd I miss that one? Wish I'd seen it then.
Quick Reply: Vortech owners - Watch out!
