Vortec question
Originally Posted by bigpurp,Jul 27 2004, 05:24 AM
I have the 9 lb pulley, but it hasn't been installed yet. I want to get my head done first.
I have an extra 11 psi pulley, and I've been running 11 psi for over a year.
I would recommend against going with 11 psi. Running that high boost you will just encounter alot of problems like I have. Broken intake retainers, broken differential, and having to replace the clutch.
Stick with stock boost, or you will be a very unhappy camper.
Originally Posted by Sideways,Jul 27 2004, 09:49 AM
Get your head done and you won't need a nine pound pulley.
Jason, tried sending you a PM, but it says your PM box is full. Lemme know when you've got that resolved.
Originally Posted by GaryRudolph,Jul 28 2004, 02:40 PM
I'd recommend to do the head work first or in combination with the 9 psi pulley. And you might was well do a Hondata gasket while you have it all apart.
Originally Posted by Calwizzy,Jul 26 2004, 11:24 PM
would i need to upgrade the injectors???
And just so you know with 9 psi I'm using the 685cc injectors and I'm at about 80% duty cycle on stock pressure (i.e. no FMU). That's without the head work. You might want 720cc for a little more room to handle a little more added fuel for the head work.
Originally Posted by buckeye1,Jul 28 2004, 12:23 PM
im running 17psi plus a 60 shot of nos....I have had no problems. (Vortech)
how "small" is your supercharger pulley? Can we have some more info on your setup?
