VooDoo Knob and Locktite help
Old 05-06-2004, 06:36 PM
Road Rage's Avatar
I have the same knob.
If you used a fresh tube of Blue threadlocker, shook it, and applied a few drops to the threads, then left it on overnight, it should be perfect. Mine has been.
And I too am amazed that some peeps missed that the whole threadlock issue is predicated by the need to align the shift pattern, which could only be done without threadlocker by sheer coincidence that the rod threads, the knob threads, and the owner's hand strength perfectly aligned.
Old 05-06-2004, 07:04 PM
bigpurp's Avatar
Or the knob etcher could screw the bare knob down all the way and align it BEFORE etching the pattern on there. But maybe each car's shift lever is different. Either that, or it's just too much to ask.
Old 05-07-2004, 03:35 PM
Banned
Red_Ohio_Rocket's Avatar
[QUOTE]Originally posted by bigpurp
I don't think 1, 2 or even 3 drops is enough.
Old 05-07-2004, 07:20 PM
Utah S2K's Avatar
Marco
Loctite?
Why?
Bob Krueger (i.e. VooDoo Bob) says the same thing.....why?
Tighten the knob and your good to go.......
Utah
Old 05-07-2004, 08:38 PM
Banned
[QUOTE]Originally posted by Utah S2K
Marco
Loctite?
Why?
Old 05-07-2004, 09:00 PM
bigpurp's Avatar
[QUOTE]Originally posted by Red_Ohio_Rocket
Thanks Big Burp... ,
Old 05-07-2004, 09:08 PM
koala's Avatar
Or, screw the knob on, with the shift pattern displayed correctly, and have it fairly "tight" in this position. Then, screw the lock nut up towards the shift knob, and gently use a wrench to tighten it a bit past your hand strength.
Old 05-09-2004, 08:59 PM
Utah S2K's Avatar
Kindas what I was thinking too......Marco?
Utah
Old 05-09-2004, 09:21 PM
Asura's Avatar
What about teflon tape?
Old 05-09-2004, 10:38 PM
Purple_sky's Avatar
Those knobs are supposed to screw on tightly. You probably got a "defective" knob. I've never had a Voodoo, but had a Muz, and it screwed on very tightly and securely.
As for locktite, I don't like it. It's like glue for metal. It makes taking off very hard. I like the knobs that screw on without any help from locktite or any other thing. Muz is nice!
zacksbro11
Tampa
18
02-10-2011 01:26 PM
b00stn
07-25-2004 01:27 PM
Gators1
08-03-2001 03:16 PM
hiho-silver
03-09-2001 03:42 PM
Quick Reply: VooDoo Knob and Locktite help
