vibrations
i was wondering if anyone has had this problem or knows about it. i bought a accident car not to bad no frame damage. The place said they had the alinement done that fixed the car. There seems to be a vibration when i accelerate for instance i could be driving in third gear and hit the gas pedal hard there seems to be a vibration in the drivedrain. I would appriciate any advice or info.
Thanks,
Justin.
Thanks,
Justin.
You should post what kind of accident it was. Front, rear, which side.
Also, are you talking about an '00? How many miles? Because it could be CVs, differential, or something that wasn't properly repaired.
i had the same problem (or at least a similar one). It wasn't as noticable in lower speeds but definitely noticable at highway speeds when accelerating.
Took it to a tech, he lifted the car and had me drive in the air. Found out it was a axle going bad.
Yours may not be the same "vibration", but its an easy check, but good luck
