Vibration in the Rear
Old 08-08-2010, 06:18 AM
s2kMyth's Avatar
When you start it up does it start vibrating immediately?
Old 08-08-2010, 02:39 PM
starchland's Avatar
what does this show?
Old 08-08-2010, 08:50 PM
sayaingokou311's Avatar
vibrating starts when i accelerate the vehicle
Old 08-08-2010, 09:08 PM
vtec4life57's Avatar
check mounts.
Old 08-08-2010, 09:21 PM
Competitor9's Avatar
Motor mounts I'd check first. If you know what a cracked one looks like and where they are it's pretty obvious.
If the car is lowered I'm not sure I understand what you said. It seems like your saying to swapped your axels with another s2000 I don't believe that will help save you from the cv bucket problem.
Read this
https://www.s2ki.com/forums/index.php?showtopic=693173
Driveshaft spacers are easy to put on just a PITA to get to. You really have to jack the car up high because your on your back the whole time and need space to work but if you have a lift its a piece of cake. I have half shaft spacers some people say they are shitty but the people that had problems didn't have problems with the spacers they had problems with the nuts coming off. T1R made mine I used some lock-tite and they are fine. The issue with getting 1-piece spacers is you have to pull off the whole driveshaft to do it.
So in conclusion motor mounts 1st and then possibly throw some spacers on
Old 08-09-2010, 12:22 AM
did swap an axle from an 03 car is currently sitting on eibach springs, 3rd gear is the worst while accelerating. Thanks for your help guys
Old 08-09-2010, 06:23 AM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
If your vibration is on acceleration only, you have pitted buckets. The axles you bought were prolly taken out for a reason.
Buckets can pit as early as 29k miles. As of now...
Old 08-09-2010, 09:07 AM
s2kMyth's Avatar
When i start my s...and it idles on the driver side the exhaust has a tinging sound and i hate it, anyone know the problem it just started today...pissing me off
Or was this covered in a post?
Old 08-09-2010, 10:36 AM
Seattle2k's Avatar
wrong thread buddy.
Old 08-09-2010, 03:59 PM
onions2k's Avatar
I get vibration on accelleration, but I've got brand new Axles! Any other ideas?
Quick Reply: Vibration in the Rear
