Vibration in the Rear
Old 08-06-2010, 10:15 AM
sayaingokou311's Avatar
Default Vibration in the Rear
Alright guys im in much needed help with this situation that im getting annoyed with. I have over 100K on my S, and I noticed some rear vibrating out of the rear about a year ago, now its gettting much worse. Keeping in mind i have an Eibach Pro Kit on the car, and as of this morning got the newer axles put in, and still have a vibrating issue. People keep talking about spacers and how that might clear up the issue. Can someone please help me with this, because frankily like i said its annoying to have to baby, that beast. Thanks for any help
Old 08-06-2010, 10:31 AM
realblag's Avatar
If you have changed the axles, spacers wont do anything for you. Maybe you have a bent wheel, a flat spotted tire, or just need balance and alignment.
Old 08-06-2010, 10:38 AM
nope they checked all that and nothing
Old 08-06-2010, 11:14 AM
anyone have any clue???
Old 08-06-2010, 07:33 PM
vtec4life57's Avatar
did you replace with pitted axles from somebody else? just go ahead and get the spacers should fix you up
Old 08-06-2010, 07:35 PM
Old 08-06-2010, 07:48 PM
i replaced my axles from an 03 with 58k miles, while i was only able to replace the drivers side rear, i still get alot of vibration while accelerating so IDK>
Old 08-06-2010, 10:42 PM
Seattle2k's Avatar
Swap the axle cups on the diff. Left to right, right to left. The pitting that vtec4life is referring to doesn't happen on the axles. It happens on the insides of the cups. Swap them and you should be good for another 100k miles!
Old 08-07-2010, 07:14 PM
would my car being lowered have any play into that??
Old 08-08-2010, 04:24 AM
Thunder-rush's Avatar
Yes, it affects..
Quick Reply: Vibration in the Rear
