Vibration/Rattle only at 70mph only during partial throttle
Old 09-14-2014, 10:23 PM
  #21
jyeung528's Avatar
Originally Posted by Slowcrash_101
That flange nut has to be torqued properly, so I hope you didn't just tighten it, it sets the preload for the pinion bearing along with the crush sleeve.
I'm not sure how it was torqued. This was done at Ballade Sports. If I recall, they described it as "didn't tighten too much to where it couldn't turn..." Or something to that effect.
Are the torquing instruction in the helm's service manual? Or is this a procedure that a differential builder would have to perform?
Would you know why or how this nut gets loose? There has been no reason I could see that anyone would touch that nut. The prop shaft has been removed twice, don't know why the nut would be messed with in either of those two circumstances. Is it a nut that could just get loose on it's own overtime?
It drives really smooth right now, so could that be an indicator that it is torqued correctly?
Old 09-15-2014, 09:55 AM
  #22
Slowcrash_101's Avatar
I'm sure they know what they're doing it just has to be to specs and it is in the fsm. A lot of bolts can come lose like the rear subframe, hell even the alignment adjuster lock nuts can come lose. It's ok to over tighten those but the diff one has to be done precisely.
Old 09-15-2014, 08:47 PM
  #23
cheddaboy's Avatar
What does this part look like? is it inside the diff?
Old 09-16-2014, 02:23 AM
  #24
When you take off the prop shaft and look at the flange that the prop shaft connects to on the diff side, in the middle of it is the flange nut, it's hidden by the prop shaft, it's just a big nut I forgot the size I think it's a 23mm.
rbtz
09-15-2017 05:58 PM
Nick_CT
06-24-2014 11:28 AM
Zikim
08-14-2013 04:12 AM
S2IM
11-25-2009 07:43 AM
StavS2K
11-19-2008 10:44 AM
Quick Reply: Vibration/Rattle only at 70mph only during partial throttle
