Vibration around 40mph?
My car started having this problem recently.
When accelerating from around 38 mph to around 48-49 my car will shake or vibrate. It happens in any gear from but doesnt happen before or after those speeds.
It only happens during acceleration, coasting in nuetral or off the gas, it will not happen.
Any help will be appreciated. Thanks
i have same probs... then i put t1r half shaft spacers.. prob went away.. but it was only a temp fix... now its back... its ur axels.... just get new ones... why rebuild... when it can just happen again... get new ones.. this happens alot to people who lower their car too...
also check ur drive shaft... for excessive play... theres a little bit .. but ull know when theres to much!!
Soo many keyboard mechanics, that are wrong.
It's not misfiring.... If it was, you'd have a check engine light on.
It's not the CV boots, they just hold the grease inside the CV joints. Boots don't cause a vibration.
Not the wheels/tires, or the vibration wouldn't go away under decel.
It is the inner CV joints, as seen here:
https://www.s2ki.com/forums/index.php?showtopic=241367
Since the pic of your car is stupid low, it will probably reoccur.
