vibration from 40-50mph
Yes. Just the buckets. Axles can't be switched as they are different lengths.
Remove axles, stand straight up, undo band clamp with pliers (great clamps, on and off super easy, definitely re-use them) lift buckets straight up and swap. If the axles are not straight up the bearing will fall off, and be quite messy.
Lol I'll take it to a mechanic to be safe!
Hope not to expensive!
I hope thats the problem otherwise I'll be spending money on the wrong thing. I'll call Honda now for a quote.
Thanks
Thanks
A mechanic will not be able to diagnose it, but you will
I can do the job in under an hour. First time guy should be under 2 hrs.
Do the road test...
Do the road test...
Do the road test...
Do the road test...
Originally Posted by Billman250,Sep 13 2010, 07:17 AM
Honda is useless. Find an independent guy to do the swap. This is not a honda job. They are not familiar and will make no money on parts.
thanks again
