valvoline tranny fluid
Old 10-19-2010, 06:07 AM
chef-j's Avatar
Thumbs up valvoline tranny fluid
I didn't see any info thru search.
Has anyone using/used this before? Any comment?
Thanks.
Old 10-19-2010, 06:42 AM
INDYMAC's Avatar
What manual transmission fluid are you talking about? I'm not aware of any.
Old 10-19-2010, 06:47 AM
chef-j's Avatar
http://www.valvoline.com/products/commerci...nd-gear-oils/78
I hope this copy/paste right add. Sorry using a phone isn't that help.
It says heavy duty tranny fluid.
Thanks.
Old 10-19-2010, 06:53 AM
INDYMAC's Avatar
If their SAE 50 grade is gear oil viscosity, then it will be too thin. If it is engine oil viscosity, then it will be too thick. I wouldn't try it in the S2000.
Old 10-19-2010, 06:57 AM
chef-j's Avatar
Thanks. What grade is for s2000?
So far I see OEM, redline, amsoil, GM and penn brands, is there other brands that I can look at?
Old 10-19-2010, 08:21 AM
CarbonCrew's Avatar
It's SAE 50 engine oil viscosity. Typically, Hondas run transmission fluids in the SAE 30 range.
Why not use Honda MTF? It's good stuff and cheap.
Old 10-19-2010, 09:37 AM
vtec9's Avatar
Old 10-19-2010, 10:57 AM
chef-j's Avatar
OEM MTF didn't give me suprise, i tried and was ok. i put pennzoil SM few months back and it feels like already shot out. I prob go with GMSMFM at this time.
Old 10-19-2010, 11:17 AM
SpitfireS's Avatar
If your MY05 really shifts that bad I would look into properly bleeding the clutch hydraulics, greasing the fork & push rod and checking the free play of the linkage.
Also, it could be the clutch disk is - after 5 years of collecting clutch dust and some rust (yes it does happen) - not able to slide over the splines that well anymore, creating crunchy shifts.
Not much to do about that with the trans installed though
Amsoil MTF works for me.. btw.
Old 10-19-2010, 11:26 AM
idea-catalyst's Avatar
another vote for Honda MTF
Quick Reply: valvoline tranny fluid
