valves?
Old 05-11-2006, 08:14 AM
Clayman's Avatar
From what I've understood all along, the valvetrain in this car is noisier than most. It's not a bad thing, it's just you can hear the slight tapping of the valves opening and closing. I'm pretty sure everybody else's car does the same thing. Unless you've noticed the car running strangely/poorly, I wouldn't get worried.
Old 05-11-2006, 08:58 AM
whitemistress2k's Avatar
Could be timing chain tensioner(TCT)... Those are noisy when going bad...
Old 05-11-2006, 06:16 PM
xtc=s2k's Avatar
samething happend to me and it was the timing chain tensioner .. its an ugly noise to hear specially doing 120mph... i would check your oil to.. i never new the S burnt a lot of oil... you learn a lot on these forums...
Old 05-11-2006, 06:27 PM
vtec9's Avatar
If the noise is centralized over the black plastic cover to the right of the valve cover, its most likely the injectors. If it sounds like a baseball card in the spokes of a bike wheel, its most likely the tensioner. If the shop you took the car with is familiar with the S2K and its noises, then I would give their diagnosis a second thought. Take a screwdriver, place the handle to your ear and move the metal end around the valve cover making note of the sound above each cylinder. You won't hear exactly the same pitch from over each, but if you hear a tap tap click click from one more than another, then you may have found the cause.
Old 05-11-2006, 07:06 PM
OvErMiNd's Avatar
How much is a tct replacement?
I have this same problem. (Baseball card in bike spokes sound.)
Old 05-11-2006, 07:17 PM
xviper's Avatar
http://www.slhondaparts.com/browse.asp?Mod...d=14510-PCX-005
Labour should be less than 1 hour.
Old 05-12-2006, 03:35 AM
http://www.hondaautomotiveparts.com/auto/j...SHAFT-CAM+CHAIN
Its #12 on this list... Good Luck...
Old 05-12-2006, 04:44 PM
xtc=s2k's Avatar
i cant belive is that cheap.. when they did mine it was under warranty the bill came out to be lil bit over $1,000 .. i wish i could find the invoice so i can post it.. this is why i love this site
Old 05-12-2006, 05:23 PM
vtec9's Avatar
good lord thats f'n ridiculous. good thing you were under warranty. no way It should be that expensive.. its quick and easy. I think there was a guy on here that had never touched his engine before but was convinced by someone to change the tensioner himself. he did it no problem in little time
Old 05-12-2006, 07:56 PM
xtc=s2k's Avatar
hey your from ct. never go to herb chambers Honda then .. i got 100k warranty in the motor anyways
Boss-S2K
06-04-2013 05:14 PM
downhil
02-06-2006 09:54 AM
stefluva
09-07-2004 08:54 PM
tboy911
05-23-2003 09:31 AM
Quick Reply: valves?
