Valve Train Clatter at Start-up
Old 06-08-2009, 09:08 AM
Banned
2007 Zx-10's Avatar
Default Valve Train Clatter at Start-up
How long is chatter noticeable after start-up in your car? Did changing to a high quality synthetic make a significant difference?
Old 06-08-2009, 09:15 AM
4evertopless's Avatar
split second on my 55kmiles 03....and no
You may have an oil pump problem if its considerably longer than that.
Old 06-08-2009, 09:25 AM
INTJ's Avatar
Try a valve adjustment first.
Old 06-08-2009, 09:40 AM
Banned
2007 Zx-10's Avatar
The car has 10k miles and has always had some minor chatter at start-up, but less apparent with a good synthetic. After about a minute or two it's silky smooth.
Old 06-08-2009, 09:42 AM
INTJ's Avatar
If that is where you are at, try the eunos 50WT, quiet as a baby.
Old 06-08-2009, 09:51 AM
Banned
2007 Zx-10's Avatar
haha, 50 weight in an S2000? not...
Old 06-08-2009, 10:09 AM
Ya id say that would even be overkill for a track only car
Old 06-08-2009, 02:58 PM
Slows2k's Avatar
Search for Timing chain tensioner noise @ cold start. There have been several videos posted of noisy chain tensioners.
Old 06-08-2009, 03:35 PM
Banned
2007 Zx-10's Avatar
I looked up the TCT vid links and that's definitely not the noise. I should go test drive a new '09 and see how it sounds.
Old 06-08-2009, 03:41 PM
Slows2k's Avatar
There are no lifters or cam buckets, the cam rides on top of the rocker, and the rocker opens the valve.
Like all "solid" cam engines, some noise will be heard from the direct contact between the rocker and valve tip.
Quick Reply: Valve Train Clatter at Start-up
