Valve Spring / Retainer Replacement
Old 01-26-2006, 08:08 PM
  #21
Slows2k's Avatar
Originally Posted by NFRS2kSi,Jan 26 2006, 12:32 PM
FYI,
buying 32 valve keeper is not going to be cheap...
u can use magnetic to keep keepers from flying out.
http://www.hondaautomotiveparts.com/auto/j...ALVE-ROCKER+ARM
32x $1.64 = $52.48 =Cheap to me.
Old 01-27-2006, 12:26 PM
  #22
Fyrestrike's Avatar
Originally Posted by steven975,Jan 27 2006, 12:55 AM
Titanium, while light, is also pretty soft. It WILL deform over time (like billman said, about 15K miles).
This is what I'm talking about. Everyone claims this, yet Honda uses Ti for the NSX rods? It just doesn't add up and there is nobody here that has had a Ti retainer fail.
Old 01-27-2006, 02:24 PM
  #23
Billman250's Avatar
Received 1,401 Likes on 839 Posts
PM Venomous S to join in here. He has done lots of research on Ti retainers. He runs them.
Old 01-27-2006, 03:57 PM
  #24
f20kills's Avatar
Originally Posted by Slows2k,Jan 26 2006, 11:08 PM
Cheap in my mind was $10
Old 01-27-2006, 05:14 PM
  #25
Fyrestrike's Avatar
Bought a Compression Tester today (mainly for the spark plug air compressor hookup) and rented an overhead valve compressor from Autozone. It looks similar to the one above but I won't know if it will fit until I try it I guess.
Old 01-28-2006, 12:03 PM
  #26
steven975's Avatar
connecting rods are under different stresses than valve retainers. titanium is actually a good metal to use for rods.
Old 02-01-2006, 10:00 AM
  #27
Fyrestrike's Avatar
Well, the job is done. The short of it is that 3 retainers were cracked, one of them in 2 places. At least another 4 retainers were dished. Also, the valve stem seals looked worn on the inside (the plastic part), maybe I should have replaced these...
I'll post pics when I get home.
Old 02-04-2006, 08:19 AM
  #28
shittles's Avatar
I, too, am on the verge of replacing my retainers.
I am leaning towards purchasing '04 retainers. Does anyone know if the '04 is a direct replacement for the ap1 retainers (any modification needed to make the '04's fit/ work)?
I was interested in the Ti retainers, but the thought of them failing and the possibilty of having to replace them after ONLY 15k miles is disheartening.
I am curious, to see the pics of your retainers fyrestrike.
-chris
Old 02-04-2006, 09:36 AM
  #29
Fyrestrike's Avatar
Here are the pics, after cleaning the retainers I actually found two more cracked ones....
Old 02-04-2006, 01:51 PM
  #30
oakfloor's Avatar
Great post, is your engine more quiet now?
Quick Reply: Valve Spring / Retainer Replacement
