Valve Spring Replacement without head removal
i used a valve spring compressor like this one.
http://www.sears.com/shc/s/p_10153_12605_0...ring+compressor
with this particular tool i ran into a slight problem. the two fingers that grab and pull up on the spring are a bit large. i had an interference problem on a few of the springs where the finger hit the head/case.
i will be doing some modifications to the tool next time i change the retainers.
Originally Posted by RED MX5,Nov 21 2007, 06:23 PM
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Originally Posted by mikegarrison,Nov 21 2007, 11:03 PM
I dropped a part into the engine. I was totally lucky to be able to get it back out again. Block up EVERY opening that parts could fall into!
I once dropped a bolt down the small side of a spreadbore carb, and then trying to fish it out I pushed the butterfly open far enough for it to fall down onto the floor of the intake manifold. Fishing the thing back out was such a PITA that it might have actually been easier if I had just gone ahead and yanked the carb.
Plugging holes is a good precaution in general, and one that I'll be using more often.
Good tip Mike.
![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
The Unabageler
03-10-2003 04:37 PM
