valve noise... possible tap
Old 11-08-2008, 12:47 PM
jonnys2k01's Avatar
Default valve noise... possible tap
ok so i dont have a vid or ne thing.. but this is exactly wat my s2k sounds like http://www.youtube.com/watch?v=fBuMdkEmtLw
i just did the valve lash.. and it still makes that noise... normal?? concerns>??? advice...
Old 11-08-2008, 12:57 PM
jonnys2k01's Avatar
if i need to rebuild... im going with brian crower dual valve springs and retainers...
but what kinda valves should i go wtih.... supertech?? brian crower... ???
Old 11-09-2008, 04:59 AM
jonnys2k01's Avatar
so yea... after i did the valve lash.. damn ticking is louderrrr grrrrr.... and now engine is running rough.... grrrrr at 1st i did min specs... then i re did it to in between the specs... 11 and 9... how much drag should it have??? tight to where u cant move it? or so u can hardly slide it...
Old 11-10-2008, 07:17 AM
ROTFLMAO's Avatar
Mine sounds like that too.
Old 11-10-2008, 03:35 PM
jonnys2k01's Avatar
should i be concerned?
Old 11-10-2008, 03:36 PM
jonnys2k01's Avatar
either rebuild head... or buy mugen hard top... by spring
Old 11-10-2008, 04:36 PM
jyeung528's Avatar
have someone else do your valve adjustment.
Old 11-10-2008, 05:36 PM
jonnys2k01's Avatar
i did it 3 times
Old 11-11-2008, 09:26 AM
jyeung528's Avatar
maybe you're not doing it correctly.
Old 11-11-2008, 09:47 AM
armthehomeless's Avatar
I went with the crower valves , there stainless steel instead of black nitrate, black nitrate valves have supposed advantages, retain less heat, smooter better flow. but there are no real numbers to support this.
If you got the extra cash, p&p and go oversized. youll need new intake seats too if you go oversized.
Quick Reply: valve noise... possible tap
