Valve covers
Valve covers
Will an AP2 valve cover fit AP1 head?
I know they are different on the sensors and stuff... but i just want it to keep my head closed till mines gets powder coated....
any stuff i need to be aware of? (cam gears grinding, ignition coils not going all the way down, screws etc etc)
The 00-05 valve covers are interchangeable, though the 00-03 and 04-05 are different. The 04-05 has a superior PCV valve design that will have a lot less oil blow-by.
The 06+ is for the 06+ only.
The exception is that if you have a Hondata ECU on a 00-05, you need a 06+ valve cover, as you're changing out all of the sensors.
Honestly pack everything with clean shop towels and close your hood and you'll be fine. I have a month long build and kept everything clean and covered that way. Though a thick plastic sheet on top for good measure.
yea, if your not driving around, thats what i did while i spent a week polishing my valve cover.
S2000 Valve cover from AP2 04-08
I know about the sensors.. i just wanna know about clearance... I just want it to move the car from point A to point B... warm it up like always do.... getting cold here...
will it at least start up? for a quick 3 bars warm up and go back to sleep
