Valve cover leaking.
This is the first I noticed it, the car only has 30,000 miles on it. It is leaking on the passenger side of the engine and around the rear of the cover as well. The strange thing is the oil seems to moistening upward on the cover itself, the red cover has a wet look almost up to the top. Is this is a common problem or should I be looking for something else? I guess I need to put a new one on and retighten it down, anything else?
Thanks!!
Thanks!!
Originally Posted by integral212,Mar 22 2008, 09:44 AM
Mine's doing it too. It's pretty easy to fix, just make sure to replace the spark plug tower seals too (this may be the source of the leak). -int212.
There is really no good reason that leaks would consistently form in that place. Are we sure this is not the result of spills when oil is added to the engine? It would result in a wet spot back there.
Definatley leaking, the oil fill is on the side. I haven't added any in a while, I was checking the oil level,that is when I noticed it. Thanks for all the replies
i had the same problem. i replaced it around 3K ago but it seems fine now. id just do the gasket you should be fine just clean off the metal surface on the head real good before re-installation
