Valve cover gasket
#31
The baffle is welded in with sonic welds (17?).
Look into the rain h8r mod. He has a detailed guide on the remove/replace procedure.
If you have a drill press and a little aptitude, it's not too hard.
#32
My '99 AP1 valve cover wasn't leaking before I did the last valve clearances and retainer inspection, so I did not bother replacing the cover seals. Still no leaks since...
From what I can tell it's the original gasket and plug well seals.
#33
Fk all this, i can get i new valve cover from Majestic Honda for $ 256.00, it would cost me that much to have it
powder coated. And i will replace all the gaskets. End of subject............
The following 2 users liked this post by Filthy Beast:
rpg51 (07-23-2021),
windhund116 (07-23-2021)
#34
I use hondapartsguy and found their pricing better. Service is OK. Use code "ship30" for 30% off shipping
#35
This is why i have been a member here for so long. Much knowledge here.
#36
BTW - I'll add my voice to the chorus and say that I have reused S2k VC gaskets many times. No troubles whatsoever. But, lately I just put in new ones for peace of mind and because I can.
#37
Received 1,716 Likes
#38
#39
Just be sure to check that the VC gasket has not partially dropped out of the VC channel before tightening the bolts. I found my gasket slipped out on intake side near firewall while dropping the VC in place. Luckily, I saw this before I mashed the gasket.
