valve clearence specs
Old 08-31-2007, 04:29 PM
spiffey28694's Avatar
Default valve clearence specs
Does anyone know what the oe clearence specs are? Any info would be greatly appreciated. Starting to sound like a vw diesel engine. Need to readjust and tighten very quickly.
thanks
Spiffey
Old 08-31-2007, 05:01 PM
PeanutButter's Avatar
21-25 intake
25-29 exhaust
Old 08-31-2007, 06:40 PM
iam7head's Avatar
Originally Posted by PeanutButter,Aug 31 2007, 05:01 PM
21-25 intake
25-29 exhaust
it would be helpful to add the unit
Old 08-31-2007, 10:01 PM
s2k dre's Avatar
0.008 intake
0.010 exhaust
Old 08-31-2007, 10:33 PM
Billman250's Avatar
Received 1,397 Likes on 837 Posts
And to add...there is no way your valves are making THAT much noise. Valves from the factory are never off (loose) more than .001-.003 tops. Surely not enough to make noise.
Old 09-01-2007, 04:04 AM
CoralDoc's Avatar
The specified range is 0.008-0.010" intake and 0.010-0.012" exhaust. Many of us adjust our valves on the lower end of this range in the hope that we will gain a little power due to the tiny increase in valve lift.
Old 09-01-2007, 04:54 AM
Old 09-01-2007, 07:36 AM
the only reason the valves are making that much noise is because the block has been built bottom and top end. When built by the shop that built I think that they may have put them on the loose end of the specs and since then there has been 5k on the engine and a lot of hard revs over 10k. The block will hold around 11k on the tach. Crazy sounding yes I know. But I have set my limiters in the ems at 10,100 max. Thanks for the help and the specs.
Spiffey
Old 09-01-2007, 09:27 AM
Billman250's Avatar
Exhaust should be .010 or .011.
Old 09-01-2007, 11:02 AM
CoralDoc's Avatar
Oops, you are correct! Why am I not surprised ... ? I just checked the Helm manual and 0.012" is out of specification for the exhaust valve.
Quick Reply: valve clearence specs
