Valve Adjustment Tool
Old 12-08-2009, 09:22 PM
Slows2k's Avatar
Enlisting dad in the project
Old 12-08-2009, 09:25 PM
AusS2000's Avatar
He has the welding equipment. Although apparently not the skills.
Old 12-08-2009, 09:27 PM
AusS2000's Avatar
Originally Posted by Slows2k,Dec 9 2009, 10:48 AM
Necessity is the mother of invention
And desperation is getting your father to weld it.
Old 12-09-2009, 07:42 PM
marcucci's Avatar
Originally Posted by AusS2000,Dec 7 2009, 08:42 PM
No torque wrench. You'd need one with and access hole through it for the screwdriver and a hollow extension like the tube spanner.
Not true- torque after setting and make sure that it hasn't moved (recheck with a feeler). In my experience, the setting will not change when torquing unless the threads were damaged by previous over-torquing.
If you do it enough times, you can calibrate your hand to the proper torque spec. That's what I've done.
Old 12-10-2009, 06:09 PM
Random1's Avatar
I just made this from a 3 in 3/8 extension and 10 mm socket. Both cost me $0.75 at a yard saile. You can put a torque wrench on there, but I usually torque after and recheck clearance.
I weld them together, but I would guess that you could epoxy them together after sanding surfaces and degreasing. Maybe JB Weld would do the trick.
Old 12-10-2009, 06:56 PM
Kirpich's Avatar
Because it's off center, your torque wrench will be way off, it's different leverage now.
Old 12-12-2009, 03:03 AM
iam7head's Avatar
nice set up but it's too fancy for me
i just need a wrench and the flathead, done countless adjustment with it like that.
Old 12-12-2009, 03:21 AM
AusS2000's Avatar
I hope you're not calling mine fancy.
Old 12-14-2009, 12:23 PM
Random1's Avatar
It is not way off as the difference from center compared to how long the torque wrench is minor. It would also vary depending on what angle the torque wrench is at, so it could be over or under.
For the 3/8 in torque wrench that I have the most it would be off is about 3 %.
0.4 inch off center
15 inch torque wrench
% error = 0.4/15 x 100% = 2.7%
I don't remember the torque for the lifters, but it it's 14 ft-lb then that would be
0.37 ft-lb off worst case depending on angle of torque wrench.
My torque wrench is good for 3% accuracy, so it could be spot on or off a bit more, but not "way off."
mattstryfe
04-12-2020 05:59 AM
BOARDPARADISE
08-31-2017 04:26 PM
andrew87890
12-25-2013 06:05 PM
S2k Eire
02-26-2009 02:16 PM
LordMagnet
08-13-2004 11:08 AM
Quick Reply: Valve Adjustment Tool
