Valve Adjustment Tool
I've had a few issues with the lock nuts on the valve adjustment coming loose. It's particularly difficult on the exhaust side as the turbo restricts access to the lock nuts and I use a bent spanner to tighten them. Apparently not enough.
My solution.
Buy one of these for $7:
Weld (rather badly) the handle to the outside of the 10mm tube spanner.
A screwdriver fits nicely through the barrel for adjustment and then just tighten the nut.
My solution.
No torque wrench. You'd need one with an access hole through it for the screwdriver and a hollow extension like the tube spanner.
You realise they are loose when the top end starts making lots of noise.
IMO, do adjustment with a screwdriver+wrench(such as ones you posted or a flex head gear wrench) then tighten with a torque wrench. Afterwards, recheck clearances with feeler. It's a pain in the ass process but better safe than sorry.
You know there is a tool made specifically for this. I just forked out the money for it. I've done so many valve lash adjustments in my time it's paid for itself.
http://www.amazon.com/Valve-Adjustment-Too...m/dp/B0009RMC50
Only difference is that mine is Mac Tools, and I only paid $35 for it.
i used one similar to the one posted above ( on amazon) and it worked great. i think i got it for around 20 or 25 shipped overnight - i forget what brand but it was cheap and made the job as easy as it coul be.
$12.99 from Amazon.
http://www.amazon.com/Alltrade-648827-2-In...60309345&sr=8-1
Alltrade 648827 10mm 7-1/2-Inch Jam Nut Valve Adjustment Tool.
