VAFC installed, Questions
The settings are prob. wrong for your car since it is a used unit. Just unplug it from the harness that comes with the VAFC, or either set the paramaters back to 0 until you get it dyno tuned.
Originally posted by Shadow_S2K
Does anyone know the stock settings? And how to reset it to stock? Thanks
Former Sponsor
Oh okey, ill try that thanks alot. So i shouldn't be smelling anything funny right? Is it possible the harness was hooked up wrong or the wiring is not right? I got this all used. Thanks
No, you shouldn't smell any funny smells, the wires should be hooked up right esp if someone else has used it, although you could check by matching all the little color labels with the color of the wires connect to the V-AFC. I just had mine dyno tuned yesterday, and made 7 more HP to the rear wheels.
[QUOTE]Originally posted by ugotmade
[B]No, you shouldn't smell any funny smells, the wires should be hooked up right esp if someone else has used it, although you could check by matching all the little color labels with the color of the wires connect to the V-AFC.
Thanks, ill be sure to check it out. What mods do you have?
Gernby, your cooling mods must have helped you more w/o the use of the V-AFC, or either you just got a better engine. I would love to have that Hondata insulater, but don't want to go through all that work to install it. At any rate great job on the mods.
Former Sponsor
Oh i was refering to you (UGOTMADE) sorry i didn't make the clear. I am going to get my car tuned by UL on Sat. and i am running AEM CAI, SPOON HEADER and EXHAUST, so i was just wondering what gains you had. Thanks
[B]
Not sure if you are talking to me or gernby, but I have an Injen CAI, test pipe (pipe to put in place of Catyletic[sp??] converter) J's racing single exhaust. as far as engine mods go.
[B]
