vafc installation problem
i just installed my vafc and i think i connected all the wires correctly. eveything seems to be correct, but my check engine light is on and it spit two codes at me. one for vtec and one for pressure. did this happen to anyone else? or should i reconnect all the wires again tomorrow (just in case any came loose). thanks for your help.
Wayne
Wayne
Former Sponsor
Np, I just want to add also that when I installed my VAFC (I got it used and with a harness) I had it custome mounted so they had to re solder the wires. They mixed two of the wires up, but it never threw a check engine light and my car ran fine. The only problem was that VTEC won't engage and it seemed to die out at around 8500 rpms. Hope it all works out for you, and make sure all your setting are initialized.
