Vafc Install
Vafc Install
I am planning on installing my vafc tonight but i had a couple questions before I started. In the VAFC installation manual it has a diagram of the s2000 ecu and the diagram does not say where the VTC cam signal, TDC signal, or a VTM signal wires are located. I was wondering if the s2000 had these wires or if they were vital to the installation of the vafc? Thanks for your help.
it sounds like you're doing the install without a harness. i'm personally not a bit fan of tapping or splicing, and if you're willing to wait, i'd suggest buying one. it's worth the trouble to save you some time finding the right wires and makes it easy to remove if you choose to later.
here's my write up. it looks the code got a bit mangled when the board was converted:
https://www.s2ki.com/forums/index.ph...&f=22&t=191575
molotovsoldier
04-17-2010 07:31 AM
