VAFC experts... plz help me
![Unhappy](https://www.s2ki.com/forums/images/icons/icon9.gif)
yes i seached hours and hours on s2ki.. coun't find any solution...
here's my story..
bought vafc 1(used) and installed by good mechanic
but after car starts... about 5 min later CEL light comes on...
same thing even i drive... about 5 min later CEL light comes on...
As soon as CEL light comes on... car goes into safe mod...
and idle is good... but as soon as i touch throttle doesn't matter how high i rev...
even with little blip... rpm comes down to almost 200rpm... just like it wants to die... and goes back to normal idle rpm... around 800-900...
so un plug battery and within 2-3 min.. i start the car again....
than it runs good... for 5 min... within 5 min.. evey thing is good...
idle, vtec all the way to 9k.... and even with blip or rev... rpm doesn't drop to
200rpm.. like safe mod...
i don't know what's going on.....
PLZ PLZ HELP ME
here's my vafc info.
car set up
cly thr
4 arrow pointing right and up
sensor
in out
06 06
all wide and narrow throttle set as zero( didn't touch anything)
throttle in point
LO Hi
80% 81% yes i tried 10% low and 50% high
V/T cnt
L-H : 6000rpm
H-L:5900rpm
option 4 v/t
Hi<<L: 0%
LO<<H: 0%
ne-p:lvt
ne1:1000
ne2:2000
ne3:3000
ne4:4000
ne5:5000
ne6:5500
ne7:6000
ne8:6500
ne-p:Hvt
ne1:4000
ne2:4500
ne3:5000
ne4:5500
ne5:6000
ne6:7000
ne7:8000
ne8:9000
what would be my problem?
wiring? or setup?
thank you so much for u help~
here's my story..
![confused.gif](https://www.s2ki.com/forums/images/smilies/confused.gif)
PLZ PLZ HELP ME
car set up
cly thr
sensor
in out
06 06
throttle in point
LO Hi
V/T cnt
L-H : 6000rpm
H-L:5900rpm
option 4 v/t
Hi<<L: 0%
LO<<H: 0%
ne-p:lvt
ne1:1000
ne2:2000
ne3:3000
ne4:4000
ne5:5000
ne6:5500
ne7:6000
ne8:6500
ne-p:Hvt
ne1:4000
ne2:4500
ne3:5000
ne4:5500
ne5:6000
ne6:7000
ne7:8000
ne8:9000
wiring? or setup?
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
It is possible that it could be your wiring. How are the wires hooked up to your ECU harness, are the wires soldered or crimped? Try unpluging you VAFC and go for a drive to see if your problem happens again.
i will try to take some pics....
![frown.gif](https://www.s2ki.com/forums/images/smilies/frown.gif)
Former Sponsor
have you tried to initialize everything again? If everything is set to zero and cycl is 4 etc...the only thing that is left is the wiring. Maybe there is a loose connection, or maybe he mixed up one of the wires. Maybe try soldering the wires together.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
make sure the wiring is all correct...i had the similar problems with my old civic using a SAFC "hack" for my turbo and it turned out one of the wires was switched...
Originally Posted by stefluva,Apr 24 2005, 04:27 AM
I've been told whenever working with an ecu crimping is a big no no. I would solder all the connections, that's how I installed mine.
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
Have you tried disconnecting the Vafc and go for a ride to see if it happens again? Have you double checked the wiring instructions?
astig00
08-24-2002 07:09 AM
