V-AFC Installation Instructions NEEDED!
To whoever is out there with a V-AFC... I need the installation instructions desperately! I am having DynoSpot Racing install and tune my V-AFC but the instructions that I have are not current (the installation sheet that I have says nothing about S2000 instructions, but "people" are saying it will work regardless). I will pay if need be!
Thanks in advance!
Andrew
Thanks in advance!
Andrew
Mmmm, you need a harness - or they will have to splice all of the wires needed. You need to do a little more research before running down there, that's my suggestion.
Wes,
It comes with a harness with open ended leads that you must splice. I was trying to hold out for the solution with the easy connector but everything is on backorder or the design has been stopped.
Is there an S2000 specific harness that the V-AFC should come with?
Ok... I am going to write up a install guide for the VAFC, with pictures. What is the exact information you are looking for and I can help you out (quick help).
Dale
Dale
DSF_S2K...readouts for the ECU connector... that is all that I can think of. The rest should be compatible to other Honda models I would think?
