Using an opened bottle of DOT 3 clutch fluid?
Old 03-01-2012, 03:59 AM
  #21
MegaTRon's Avatar
dang. your brake reservoir looks clean like brand new. its so white. lol
Old 03-01-2012, 04:10 AM
  #22
SpitfireS's Avatar
Originally Posted by dwight
In addition noticing that they didn't mix in the waste bottle, I noticed that they didn't mix in the reservoir.
I would be seriously concerned if this happened to my car.
And I'm as serious as can be, we're talking brakes.
Until now I only worked with the glycol based brake fluids.
If you get some on your hand / fingers it feels "not smooth" not like oil, not greasy - if you know what I mean.
Can you get a sample of the old fluid?
You can compare it with the fresh fluid you have.
If there is a noticable difference = bad!
Someone may have used a DOT 5 fluid in your brake system.
Or, in any case, a fluid that is not compatible with DOT 3, 4 or 5.1 fluids.
Maybe regular hydraulic fluid.
This fluid is now in your ABS unit, where it will be difficult - if not impossible - to remove.
How do the brakes feel?
As firm as they did before?
Old 03-01-2012, 04:35 AM
  #23
dwight's Avatar
It's not clean. The photo is just overexposed from pushing +2 EV in post.
Originally Posted by SpitfireS
I would be seriously concerned if this happened to my car.And I'm as serious as can be, we're talking brakes.Until now I only worked with the glycol based brake fluids.If you get some on your hand / fingers it feels "not smooth" not like oil, not greasy - if you know what I mean.Can you get a sample of the old fluid?You can compare it with the fresh fluid you have.If there is a noticable difference = bad!Someone may have used a DOT 5 fluid in your brake system.Or, in any case, a fluid that is not compatible with DOT 3, 4 or 5.1 fluids.Maybe regular hydraulic fluid.This fluid is now in your ABS unit, where it will be difficult - if not impossible - to remove.How do the brakes feel?As firm as they did before?
Brakes felt great before. Still feel great now. There were only a few drops of the floating yellow fluid. I used a turkey baster to siphon out the old fluid and then used a towel to clean out the reservoir. I didn't notice the floating yellow fluid until after I bled the first caliper and then I was able to suck most of it out. I refilled and bled the next. When it was low again, I siphoned out the rest of the specs so now it's clean.
I doubt someone put DOT 5 in there. I believe that the car was pretty well maintained. My clutch and brake fluids were pretty clean. Even my cabin air filter was clean.
Old 03-01-2012, 04:45 AM
  #24
Billman250's Avatar
Received 1,396 Likes on 837 Posts
When I do the ATE blue change over, there is always a touch of factory brake fluid left that cannot be removed. It mixes 100% with the blue and never has any little floaties
Dwight I think you have sone serious contamination there. But as with all internet pics, I could tell you more with the car in front of me.
Old 03-01-2012, 04:51 AM
  #25
dwight's Avatar
Perhaps it came from my turkey baster that I used to suck out the old fluid.
Either way, I'm pretty sure that I sucked it all out. After each caliper I skimmed the top to suck it out before topping it off and moving on to the next caliper. By the time I was done with the last one, I didn't see anything before topping it off.
Old 03-01-2012, 04:55 AM
  #26
Killin9's's Avatar
billman ftw!
S2KBert
04-28-2015 06:17 PM
S2kRally
09-24-2010 04:23 AM
chilled
05-17-2007 06:03 AM
Cyber Logic
10-11-2001 12:05 PM
Quick Reply: Using an opened bottle of DOT 3 clutch fluid?
